    Hi all,
    I have been a lurker on the forum for a long time. I recently picked up a crusty looking boxford 160 lathe, I have cleaned it up and I am planning on refitting the control to something more 21st century. All the advice so far is pointing to Linux CNC.
    Here is the first video of the clean up:
    Next job is to try to get the spindle moving. Does anybody have a wiring diagram or any experience of trouble shooting the dc drive on these things?
    I posted this on another forum, they gave good advice but I think there is more likely to be first hand experience with these machines on here, being uk based.
    Appreciate the help!
    Andrew
    BTW feel free to have a look at my other videos. there is a random assortment of all sorts of projects on there
    Lives in Plymouth, United Kingdom. Last Activity: 19 Hours Ago Has a total post count of 1,748. Received thanks 299 times, giving thanks to others 11 times.
    Interesting project. I have just about, bar a bit of tidying up, finished an electronics refresh on a Denford Orac. It came to me halfway through a project by the previous owner, meaning that he had stripped everything out and just started rebuilding. It uses straightforward steppers (driving ballscrews), simple microswitch limit switches, and a VFD driving the spindle motor. All easy stuff to drive. I spent quite a lot of time puzzling over what to put in.
    I considered LinuxCNC but at that time the best interface card - didn't want to drive via a parallel port - was the Mesa ethernet card. However, every time I looked it only seemed to be available directly from the US and they always claimed to be out of stock. I'm told that this has now changed. I did consider the UC300 from CNCdrive as I use a couple of these already along with their UCCNC control software but their promised lathe-compatible update was still in development. It appeared not long after I ordered a PlanetCNC TNG board with their control software instead as this promised lathe support. It seems to do everything I might want except for constant surface speed. I understand that UCCNC does this as well.
    There isn't a one-size-fits-all solution - depends on things like how comfortable you are with Linux and doing the software configuration to make it work in your system, whether you want a more-or-less turnkey system and suffer Windows, or whatever. Personally, I regret not having ordered the motion control hardware and software a month or so later than I did as I'm familiar with it on a mill and router but what I have seems to do what's needed - for me. Then there is the Acorn hardware and software, which seems to get good reports from its users. Kmotion/Kflop and its friends get good reports - but again, only from people who have made them work!
    Good luck!
  1. Bridgeport Series 1 Interact. Refit/update . Opinions please.
    By swarf-boy in forum Bridgeport Milling Machines
    Last Post: 03-11-2024, 02:56 AM
  2. SIEG iKC4 Lathe - ATC issues and refit
    By PeterE in forum Sieg Lathes
    Last Post: 28-07-2022, 05:41 PM
  3. NEW MEMBER: Boxford 160 Refit
    By dunning123 in forum New Member Introductions
    Last Post: 27-04-2021, 07:17 AM
  4. FOR SALE: For Sale Bridgeport MDI Series1 CNC part finished refit
    By Norman12 in forum Items For Sale
    Last Post: 19-12-2018, 10:22 PM
  5. Replies: 2
    Last Post: 21-04-2016, 09:18 AM
