22-09-2021 #10
Thanks for your reply, I read it back a good few times on Sunday to try to break it down and understand how the GEC board works, but no unfortunately I have no info on this at present. Indeed my board does appear to have similar connections to your Sprint board although the layout is different.
I’m up for trying the “switch & pot” although I have no idea what a pot is, haha. I won’t be able to try this until next week however as my schedule for this week is pretty crammed
In regards to the two other boards you asked about, the small one is a relay board. It feeds relays 1 and 2 for the motor direction. If the other board is a PWM generator that might explain what my next step is within Mach3 > Ports & Pins > Spindle Setup
Also, I’ve just picked up an old Denford Starmill from a friend so that’ll be the next project once I get the TCL running :)
MK4 MACH3 Motion Card Problem with output control ports. NEED HELP!
By Mushtantuk in forum Motor Drivers & ControllersReplies: 0Last Post: 18-06-2017, 02:36 PM -
Mach 3 ports and pins problems,
By chris w in forum Artsoft Mach (3 & 4)Replies: 24Last Post: 06-04-2017, 03:25 PM -
Mach3 ports and pin setup to match my control box
By Sparky in forum Artsoft Mach (3 & 4)Replies: 17Last Post: 13-11-2014, 04:00 PM -
ports and pins for system4
By Dan Brown in forum Motor Drivers & ControllersReplies: 2Last Post: 18-01-2010, 06:37 PM -
Ports and pins help ? mach 3
By xchipx in forum Artsoft Mach (3 & 4)Replies: 0Last Post: 19-04-2009, 12:45 PM
