22-09-2021 #11
A pot is a potentiometer . Intended to vary voltage for a number of possible applications .
With these drivers a varying voltage input between 0 and 10 v dc causes a varying output voltage typically from 0 v to 170 volts or so, which will give full motor speed .
Most drives have a 10 v output terminal and a ground terminal across which a 10 kilohm resistor can be connected . A wiper brushing along the length of this resistor will pick up a proportion of this 10 volts from 0v to 10v which is used to feed the input terminal and this is all that a potentiometer does. This in turn causes it to give an output voltage to the motor between a minimum of zero volts which leaves it stationary , to say 170 volts which gives it full chat . This is the simple way to operate and indeed prove one of these drivers. And this is what we are aiming to prove by connecting a pot .
Then In our case we want the computer to send the signal voltage which will vary the motor speed under program control , so the PWM output is used .
This may need to be converted to a 0-10v analog output which many modern breakout boards handle, or I suspect in your case the PWM output may be used to generate a the 0-10v analog input which is needed to control your motor in a separate board . This then replaces the function of the Pot.
A pic of that board would be helpful to try and establish that is correct.
MK4 MACH3 Motion Card Problem with output control ports. NEED HELP!
By Mushtantuk in forum Motor Drivers & ControllersReplies: 0Last Post: 18-06-2017, 02:36 PM -
Mach 3 ports and pins problems,
By chris w in forum Artsoft Mach (3 & 4)Replies: 24Last Post: 06-04-2017, 03:25 PM -
Mach3 ports and pin setup to match my control box
By Sparky in forum Artsoft Mach (3 & 4)Replies: 17Last Post: 13-11-2014, 04:00 PM -
ports and pins for system4
By Dan Brown in forum Motor Drivers & ControllersReplies: 2Last Post: 18-01-2010, 06:37 PM -
Ports and pins help ? mach 3
By xchipx in forum Artsoft Mach (3 & 4)Replies: 0Last Post: 19-04-2009, 12:45 PM
