Thread: CNC 3018 PCB drill bit break
For info, I’ve done reasonable isolation routing using 0.3mm dia end mills. Those have a cutter length about three mm and will snap if you look at them wrong. But great cut compared to v cutters, but together with their fragility are wickedly expensive. To OP, dial out all your other problems before entering the world of exotic cutters.
It’s this experience that resulted in the question whether the image of the snapped cutter is an end mill or a PCB drill. The cutter length looks to be too long for a cutter suited to PCB, but your experience may vary
25 year break. The Internet changed things!
By Blazing Black Beard in forum New Member IntroductionsReplies: 2Last Post: 05-09-2018, 03:00 PM -
are these a newwer version usb break out board the ones from austrailia - better?
By nobby in forum General ElectronicsReplies: 0Last Post: 13-02-2014, 07:09 PM -
optoport v3 break out board wiring
By lez allen in forum Motor Drivers & ControllersReplies: 4Last Post: 26-02-2013, 07:38 PM -
Requirements on a break out board?
By Sodster68 in forum Motor Drivers & ControllersReplies: 3Last Post: 21-01-2013, 02:58 PM -
Motor controller next to break out board?
By m_c in forum General ElectronicsReplies: 2Last Post: 17-11-2010, 01:56 PM
