Thread: CNC Router purchase advice
I'm looking to buy a cnc with a budget of around 13-16 k
It would need to fit 8x4 sheets.
Generally it would be used to cut patterns in 6mm birch ply,6mm melamine faced mdf and HPL 6mm ply.
I have been looking at the Olympus 1325 from Opus and the M5S from Exel.
I'm drawn to the Opus as you get training with the software on installation.
I have 3 phase extraction in the unit already.
Any advice would be great.
cheers
Dom
11-09-2021 #2
This post might be a bit light on replies as a lot of members on here have either built their own from scratch, converted a milling machine to CNC, or have had a custom machine made. For the custom option try Dean from JazzCNC for a quote, his email address is in the signature of his posts. That looks like a healthy budget so I expect that would allow a very capable machine.
13-09-2021 #3
Ok great thank you for the response
16-09-2021 #4
As i see both looks the same , i think u need the one with servo and atc , i will get the one who weights more , because there is more mass and i think is more rigid .
Now i look at datasheet and seems olimpus is way rigid than m5s, and if i where u i will go straight to olimpus , because it weights 50 percent more than m5s , this will help u with rigidity and finish on cutting .
I dont think u need a 9kw spindle if u cut only 6mm plywood , a 5kw will do same job .
U need servo , and spindle to have 24000 rpm , and up down mill cuter bit .
22-09-2021 #5
If I had £16k to play with then I too would be hounding Dean (jazzcnc) down for sure :) there is some talented guys on here but Dean is known world wide, no matter what website I am on I see his name everywhere when it involves cnc builds
04-12-2021 #6
if you are still looking. i stock fully upgradeable 8 by 4 size machines in the uk.
take a look at a few working videos . https://www.youtube.com/watch?v=sxoR...chGyedqfKKIWQt
Advice on seller to purchase 2.2kw air cooled spindle from pretty please
By STK2008 in forum Generic Chinese SpindlesReplies: 12Last Post: 20-03-2020, 06:17 PM -
profile rail and purchase advice
By johngoodrich in forum Marketplace DiscussionReplies: 2Last Post: 17-09-2016, 07:53 PM -
CNC purchase advice
By boxmaker in forum Marketplace DiscussionReplies: 2Last Post: 03-11-2013, 06:55 PM -
Advice needed on Mill Purchase
By davegrennan in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 30-08-2011, 10:41 PM
