  1. Hi,
    When first starting UCCNC the jog speed is set to 10%. Can I change this and is there explanation of other default settings available?
    Thanks Simon.
    Kitwn's Avatar
    Lives in Don, Tasmania, Australia. Last Activity: 4 Weeks Ago Has been a member for 7-8 years. Has a total post count of 985. Received thanks 118 times, giving thanks to others 52 times.
    It may well be in the profile somewhere. You can open it in any text editor for a look. Otherwise the CNC Drive forum is very good. The staff check on the forum regularly and are good at replying to questions.
    EDIT: Just had a look at my profile (it will be called Default.pro unless you have set up another profile of your own). I did a search for 'jog' and for 'speed'. The only likely candidate is line 417 "MPG1speedmultiplier=10" but I cannot find any reference to what MPG1 is so the software's own forum is probably the best place to ask.
    Kit
    https://forum.cncdrive.com/
    Quote Originally Posted by Cube3 View Post
    Thanks Simon.
    There is no way to do this from within UCCNC settings etc(that I know about), however, it can be done by writing the following code into what's called the Constructor macro M99998 which will you find in the Profiles folder inside a folder starting with Macro_(Same name as your profile) if you didn't name your profile then it will be in the Macro_Default folder.
    AS3jog.Setfield(50, 913);
    AS3jog.Validatefield(913);
    You must copy it exactly as above as it's case-sensitive. To change the Jog speed to suit your needs replace the 50 with the value you want. Then restart UCCNC if it is running for it to take effect.
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
  1. How-To: Feed Rate Calculation
    By Lee Roberts in forum Machine Discussion
    Last Post: 25-03-2020, 04:09 PM
  2. Feed rate on Denford microrouter
    By andy_con in forum Denford Routers
    Last Post: 02-11-2019, 03:42 PM
  3. Tool wear rate...
    By Davek0974 in forum Tool & Tooling Technology
    Last Post: 23-10-2016, 05:53 PM
  4. SSO/FRO (Spindle Speed/Feed Rate Override)
    By m_c in forum General Electronics
    Last Post: 17-10-2016, 11:14 PM
  5. Router bit recommendation, spindle speed and feed rate?
    By FlightCaseCo in forum Spindles & Drive Motors
    Last Post: 03-04-2012, 12:53 PM
