    It is a OMRON LY2NJ. The Spec sheet is easy to find on the Web.
    Quote Originally Posted by JohnnyCimino View Post
    Ok, this is the same relay we sell and use so I know it well.
    Now tell me the pin numbers you are using for the Com and the NO and NC contacts for each set of contacts.?
    Edit: forget that I've just seen your post
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
    So testing the spindle with NO POWER you should get continuity between #6 - # 2 and #5 - #1. with NO continuity between #6 - #4 and #5 -#3.
    Then with power applied you should get continuity between #6 - #4 and #5 -#3 with NO continuity between #6 - #2 and #5 - #1.
    If you get anything else then you have a faulty relay.
    Also, you don't need to use the second set of NC contacts for the ATC release, you can just use the NC of the first set of contacts because it will change over when the relay turns on. HOWEVER, if you are using this to actually release the tool rather than just forming an inhibit to the solonoid it's a very bad idea because every time the spindle stops it will drop the tool.?? . . . Surely this is not what you meant.!
  1. ATC Spindles air connections inquiry
    By Noplace in forum Spindles & Drive Motors
    Last Post: 08-04-2021, 07:57 AM
  2. Terminal blocks or similar for power distribution in cabinet
    By Neale in forum General Electronics
    Last Post: 27-10-2020, 02:57 PM
  3. Sunfar E550 VFD....anyone have any experience please?
    By Voicecoil in forum Gantry/Router Machines & Building
    Last Post: 05-12-2018, 09:40 PM
  4. Problems with my CNC using Mach3 with a Sunfar E300 Inverter
    By Malcolm in forum General Discussion
    Last Post: 20-04-2017, 12:46 PM
  5. Terminal blocks
    By Rogue in forum General Electronics
    Last Post: 19-09-2012, 11:01 PM
