Thread: Denford orac lathe spindle
I used a VFD on my orac. Using linuxcnc but would work equally well with mach3
Mach3 will struggle with threading as it only uses a single pulse per Rev to sync the spindle to the Z axis
I cut perfect threads using the original orac spindle encoder. 48 pulses per Rev so syncs 48 times per Rev which is very important on a small lathe that will bog down under threading loads as no back gear etc
I get good torque out of the orac three phase motor and spindle speeds from 50 rpm ( for clocking not cutting ) to 2200 rpm
Paul
Denford ORAC lathe spindle nose upgrade
By rnr107 in forum Metalwork Project ShowcaseReplies: 19Last Post: 29-04-2019, 07:45 AM -
Denford Orac and CS Labs controller
By swdiver in forum Denford LathesReplies: 4Last Post: 07-08-2017, 10:59 PM -
FOR SALE: Denford Triac + Denford Orac + other stuff
By Clive S in forum Items For SaleReplies: 6Last Post: 06-02-2017, 11:47 PM -
WANTED: Denford Orac old electronics
By matoxx in forum Items WantedReplies: 2Last Post: 27-07-2016, 06:55 PM -
RFQ: Spindle for a Denford ORAC
By rnr107 in forum Projects, Jobs & RequestsReplies: 0Last Post: 07-11-2012, 05:20 PM
