Thread: Will grease do for linear rails
	24-09-2021 #1
Instead of putting tubes (hoses) to all carriages and having central lubing system, I was thinking that since I will not use machine every day or even every week for that sake that I just grease the carriages once in a while. LinuxCNC can tell how far the machine has traveled and can grease with that info.
Hiwin recommends oil at higher speeds but grease goes a long way according to Hiwin datasheet.
Any pros and cons?
	24-09-2021 #2
Yes, it will be perfectly fine, even if used every day. Just clean the rails every few days and put a few drops of oil on the rails and run up and down. Depending on usage then grease it every few months. Mostly just use common sense and if they seem a little dry give them some grease.!
Email: [email protected]
Web site: www.jazzcnc.co.uk
Linear rails
By Crunch in forum Gantry/Router Machines & BuildingReplies: 9Last Post: 11-06-2019, 10:58 PM -
Misumy linear rails
By Boyan Silyavski in forum Linear & Rotary MotionReplies: 5Last Post: 11-05-2017, 03:46 PM -
FOR SALE: Minebea psu and linear rails
By Iwant1 in forum Items For SaleReplies: 2Last Post: 15-07-2012, 10:55 PM -
FOR SALE: ballscrews, supported linear rails, linear bearings, complete kit. for sale
By cutter in forum Items For SaleReplies: 0Last Post: 04-12-2011, 03:23 PM -
THK linear bearing rails
By Tonyel in forum Rails, Guideways & BearingsReplies: 0Last Post: 01-11-2008, 03:21 PM
