    does the y axis have to match the x axis when spacing the bearings and is it measured from center to center or outer edge to outer edge? reason i ask is because from center to center my bearings on the x axis is 200mm with 300mm long plates bolted to 2 bearing blocks but if i match the y axis to the same distance it is making my z axis plates wide and so making the total width of the machine wider which i don't want.
    Thanks again
    AndyUK's Avatar
    Lives in Southampton, United Kingdom. Last Activity: 2 Weeks Ago Has been a member for 8-9 years. Has a total post count of 475. Received thanks 104 times, giving thanks to others 43 times. Referred 1 members to the community.
    Quote Originally Posted by reefy86 View Post
    Thanks again
    There is nothing to say that your X and Y bearings should be spaced equally, and you can measure the distance however you fancy. Obviously the farther apart they are the greater their ability to resist the twisting moment.
    If it helps, my build has an outer edge to outer edge bearing distance of 270mm on X and 150mm on Y. As you say, any more and you lose significant amounts of travel.
  1. FOR SALE: linear bearing
    By xadmx in forum Items For Sale
    Last Post: 26-09-2019, 07:46 AM
  2. Moving bed - bearing spacing?
    By Snapper in forum Gantry/Router Machines & Building
    Last Post: 13-10-2017, 10:18 AM
  3. Bearing Spacing on Y-Gantry-Carriage
    By WandrinAndy in forum Gantry/Router Machines & Building
    Last Post: 29-10-2012, 01:16 AM
  4. FOR SALE: Linear rail and bearing
    By black5f in forum Items For Sale
    Last Post: 02-07-2010, 07:23 PM
  5. THK linear bearing rails
    By Tonyel in forum Rails, Guideways & Bearings
    Last Post: 01-11-2008, 03:21 PM
