Thread: linear bearing spacing
18-09-2021 #1
does the y axis have to match the x axis when spacing the bearings and is it measured from center to center or outer edge to outer edge? reason i ask is because from center to center my bearings on the x axis is 200mm with 300mm long plates bolted to 2 bearing blocks but if i match the y axis to the same distance it is making my z axis plates wide and so making the total width of the machine wider which i don't want.
Thanks again
19-09-2021 #2
There is nothing to say that your X and Y bearings should be spaced equally, and you can measure the distance however you fancy. Obviously the farther apart they are the greater their ability to resist the twisting moment.
If it helps, my build has an outer edge to outer edge bearing distance of 270mm on X and 150mm on Y. As you say, any more and you lose significant amounts of travel.
FOR SALE: linear bearing
By xadmx in forum Items For SaleReplies: 3Last Post: 26-09-2019, 07:46 AM -
Moving bed - bearing spacing?
By Snapper in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 13-10-2017, 10:18 AM -
Bearing Spacing on Y-Gantry-Carriage
By WandrinAndy in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 29-10-2012, 01:16 AM -
FOR SALE: Linear rail and bearing
By black5f in forum Items For SaleReplies: 5Last Post: 02-07-2010, 07:23 PM -
THK linear bearing rails
By Tonyel in forum Rails, Guideways & BearingsReplies: 0Last Post: 01-11-2008, 03:21 PM
