Page 2 of 2 FirstFirst 12
    You could put a shim 1.5mm in the gap or machine the BK and BF mounting plate 1.5 thinner.
    You could also remake the top plate wider so the you bolt the ball nut plate down from the top and adjust it with slots in the top plate
    I think Dean meant something like this. Extend the bearing plate rearward, rotate the ballnut around its axis 90 degree and bolt down through the plate into the ballnut housing
    Quote Originally Posted by reefy86 View Post
    do you have a pic showing the ballnut housing position Dean? here is what mine looks like but it has a plate hanging from the bearing plate for the ballnut housing.
    also how do you guys solve issues like the ballnut housing being 1.25mm away from the plate its supposed to bolt on to? i have gone of the measurements from bst automation and i would of thought the ballnut housing along with both bk and bf ends would all be level with each other unless something has not aligned right in cad?
    Sorry, don't have a picture showing that part clearly... But it's not rocket science either.! The top bearing plate extends out just past the ball nut housing which as the mounting holes facing upwards to meet the plate, there are slots milled into the plate to allow adjustment. Then between the BK bearings plates which have slots, you have adjustments in both directions.
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
    Dean or Clive !!
  5. #15
    Dean or Clive !!
    Sorry Clive I misread your post (long day!) but actually it says the same thing!
    1 point each !
  6. The Following User Says Thank You to routercnc For This Useful Post:
  7. #16
    Ay! some of the stuff you come out with is rocket science to some lol. but yeah this does make it sound simple now. pic below shows what i was going to do but yours is much more simple
  8. #17
    thank you mate
  9. #18
    just a quicky
    do these new and improved closed loop 5nm+ motors allow for extra weight to be added on the gantry? not that i want to add extra weight but this leads onto my last question. between the top and bottom bearing plate would there being any advantages to having a solid plate attaching to both of those or would it hinge things? its extra weight but if it will do nothing but add weight i wouldn't want to have it.
    Thanks again
  1. Retro fit core drill for motorised z axis suggestions
    By Fivetide in forum Other Machines & Building
    Last Post: 08-06-2018, 10:46 PM
  2. single and 3 phase motor sizing and mounting ?
    By Musht in forum General Electronics
    Last Post: 27-10-2013, 09:58 PM
  3. Mounting motor under table?
    By Rogue in forum Linear & Rotary Motion
    Last Post: 16-04-2012, 04:02 PM
  4. Dilemma with ball screw and motor mounting
    By luke11cnc in forum Lead Screws, Nuts & Supports
    Last Post: 12-08-2011, 10:58 AM
  5. 2 ways of mounting motor
    By Steve-m in forum Gantry/Router Machines & Building
    Last Post: 28-02-2009, 01:12 AM
