20-09-2021 #11
20-09-2021 #12
20-09-2021 #13
Sorry, don't have a picture showing that part clearly... But it's not rocket science either.! The top bearing plate extends out just past the ball nut housing which as the mounting holes facing upwards to meet the plate, there are slots milled into the plate to allow adjustment. Then between the BK bearings plates which have slots, you have adjustments in both directions.
Email: [email protected]
Web site: www.jazzcnc.co.uk
20-09-2021 #14
20-09-2021 #15
21-09-2021 #16
21-09-2021 #17
21-09-2021 #18
just a quicky
do these new and improved closed loop 5nm+ motors allow for extra weight to be added on the gantry? not that i want to add extra weight but this leads onto my last question. between the top and bottom bearing plate would there being any advantages to having a solid plate attaching to both of those or would it hinge things? its extra weight but if it will do nothing but add weight i wouldn't want to have it.
Thanks again
Retro fit core drill for motorised z axis suggestions
By Fivetide in forum Other Machines & BuildingReplies: 4Last Post: 08-06-2018, 10:46 PM -
single and 3 phase motor sizing and mounting ?
By Musht in forum General ElectronicsReplies: 5Last Post: 27-10-2013, 09:58 PM -
Mounting motor under table?
By Rogue in forum Linear & Rotary MotionReplies: 51Last Post: 16-04-2012, 04:02 PM -
Dilemma with ball screw and motor mounting
By luke11cnc in forum Lead Screws, Nuts & SupportsReplies: 4Last Post: 12-08-2011, 10:58 AM -
2 ways of mounting motor
By Steve-m in forum Gantry/Router Machines & BuildingReplies: 8Last Post: 28-02-2009, 01:12 AM
