Yep, that will work nicely. Even 10mm works.
side note on the plates for the BK bearings, if you look at my pic you'll see the plates actually lift the ball-screw just above the profile, this is so the ball-nut housing will attach directly to the X-axis bearing plate rather than using a drop-down bracket.!
do you have a pic showing the ballnut housing position Dean? here is what mine looks like but it has a plate hanging from the bearing plate for the ballnut housing.
also how do you guys solve issues like the ballnut housing being 1.25mm away from the plate its supposed to bolt on to? i have gone of the measurements from bst automation and i would of thought the ballnut housing along with both bk and bf ends would all be level with each other unless something has not aligned right in cad? picture is below to show what i mean.
thanks
