Thread: Denford Triac Spindle Issue
28-09-2021 #7
What hasn't been mentioned, is the spindle drive fuse was blown (there's a concurrent thread over on the Denford forums).
I've just had a look at the wiring diagram, and the fuse should be 6.3A.
If the motor stutters/stalls briefly when running, it's could be either the SCRs on the drive are failing (they tend to fail short circuit under certain loads, which causes the stuttering/stalling), or the motor is either shorting out internally, or the brushes are not making good contact (which again gives the stuttering/stalling).
The issue with the spindle motor, is due to it having a tacho fitted, beyond removing the brushes, they are a nightmare to dismantle and clean.
I personally removed the DC motor and sprint drive from mine, and retrofitted it with a servo motor and drive.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
By GingerNinja54 in forum Denford MillsReplies: 1Last Post: 21-09-2021, 10:58 PM -
WANTED: Denford triac lynx spindle drive board
By mark35gun in forum Items WantedReplies: 4Last Post: 10-01-2021, 02:38 PM -
Denford Triac Spindle control / ATC
By RocketBoy in forum Denford MillsReplies: 21Last Post: 24-01-2018, 12:35 PM -
3kw Chinese Spindle - ER20 denford triac question
By andy_con in forum Denford MillsReplies: 13Last Post: 03-11-2015, 10:14 PM -
Denford Triac Spindle Fault
By Sam_Smith in forum Denford MillsReplies: 5Last Post: 04-05-2011, 11:07 PM
