  1. #15
    Lives in East Lothian, United Kingdom. Last Activity: 16 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,989. Received thanks 373 times, giving thanks to others 9 times.
    Quote Originally Posted by John11668 View Post
    From what I can see sprint 1200 is a non isolated drive .
    I am told that a potentiometer should control speed even directly connected but it will be supplying an input at the mid point of 170v or so. if you want to send signals from the computer there has to be an intervening board .
    There is an intervening board. The Baldor controller that Denford fit to their machines.
    However I'm not sure if the Baldor controller does the isolation, if there is a separate isolated supply for the Baldor controller specifically for the speed control, or if the analogue speed control is done by a totally separate board.
    There is also the added complication that this machine has been upgraded from it's original serial controller to a USB controller, so I don't know how much may have been changed from the wiring diagrams that are available on the Denford forums.
    I know KB drives of that era often had an option for isolated inputs, but I don't think Sprint did.
    GingerNinja, have you traced where the 54/55 wires go to? Do they connect to the controller, or do they connect to the drive rack?
  2. The Following User Says Thank You to m_c For This Useful Post:
  1. Denford Triac Spindle Issue
    By GingerNinja54 in forum Denford Mills
    Last Post: 21-09-2021, 10:58 PM
  2. WANTED: Denford triac lynx spindle drive board
    By mark35gun in forum Items Wanted
    Last Post: 10-01-2021, 02:38 PM
  3. Denford Triac Spindle control / ATC
    By RocketBoy in forum Denford Mills
    Last Post: 24-01-2018, 12:35 PM
  4. 3kw Chinese Spindle - ER20 denford triac question
    By andy_con in forum Denford Mills
    Last Post: 03-11-2015, 10:14 PM
  5. Denford Triac Spindle Fault
    By Sam_Smith in forum Denford Mills
    Last Post: 04-05-2011, 11:07 PM
