    Update:
    With slider at TAC = spindle fires up to high revs and sometimes trips my supply RCD!
    If it doesn't trip the RCD, I can usually (not every time) start/stop the spindle in VR5, but not alter rpm.
    With slider at AVF = spindle fires up to lower revs (1k rpm?) then stops.
    I am not able to start/stop the spindle in VR5.
    Wires #54 & #55 removed from Sprint1200 = spindle does fire at all
    Wires #54 & #55 linked out on #1 & #3 connector on Sprint1200 = same as with #54 & #55 in position (incl same with the TAC/AVF slider)
    At startup, both TAC/AVF, I measure 11.5v across #54 & #55
    The only spindle settings I can see in VR5 are max/min rpm, and check boxes for manual, speed pot & external speed pot...
    Help!
    I think you should contact sprint for advice .
    I found they were a helpful bunch
  1. Denford Triac Spindle Issue
    By GingerNinja54 in forum Denford Mills
    Last Post: 21-09-2021, 10:58 PM
  2. WANTED: Denford triac lynx spindle drive board
    By mark35gun in forum Items Wanted
    Last Post: 10-01-2021, 02:38 PM
  3. Denford Triac Spindle control / ATC
    By RocketBoy in forum Denford Mills
    Last Post: 24-01-2018, 12:35 PM
  4. 3kw Chinese Spindle - ER20 denford triac question
    By andy_con in forum Denford Mills
    Last Post: 03-11-2015, 10:14 PM
  5. Denford Triac Spindle Fault
    By Sam_Smith in forum Denford Mills
    Last Post: 04-05-2011, 11:07 PM
