    how do you guys get around fixing bk supports to y axis? i need to attach a plate to the frame and then the bk support to the plate but the side of the frame is definitely not going to be flat especially either end which means both bk fixed supports wont be true to each other.
    originally was just going to have thick welded plates each end of the machine with a slot cut out for the screw to align and tension both ends but i cant get ballscrews longer then 2900mm to be shipped so got to use bk supports instead.
    edit!!! never mind stupid question, always think of something after i ask a question and never before
    Hopefully, you realized it was a stupid question because you are planning on using a rotating ball nut so you don't need or indeed want a bearing of any kind.? The screw must be fixed solid and not allowed to rotate at all.!
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
    Hoping you wasn't going to notice lol. Couldn't delete the post but I was focused on getting both ends if the screw fixed but forgot those fixed supports turn with the screw.
    Quote Originally Posted by reefy86 View Post
    I miss nothing....Lol
    just a rough template here but if the machined end ballscrew is 20mm what would be a decent amount of clearance on this adjustable plate? would you have the hole cut out at 20mm for tight fit so then the ball screw can be adjusted back and forth like i have done in the pic or have the hole slightly bigger then 20mm so it can also be adjusted up and down slightly?
    probably better ideas then what im doing here but cant find any designs ideas to look at as most are using bk supports.
Name:	ballscrew fixed end.jpg
ID:	30481Click image for larger version.
Name:	ballscrew fixed end2.jpg
    try not look an idiot next time then lol
  1. FOR SALE: Ballscrew supports and Motor mounts on sale
    By Gary in forum Items For Sale
    Last Post: 13-12-2019, 11:38 AM
  2. Experience with fixed - fixed ball-screws vs fixed - supported?
    By PotatoMill in forum Gantry/Router Machines & Building
    Last Post: 16-05-2016, 08:37 PM
  3. FOR SALE: SFU1605 500mm + end supports + nut
    By eurikain in forum Items For Sale
    Last Post: 14-01-2016, 06:58 PM
  4. supports for ballscrews
    By leadinglights in forum Lead Screws, Nuts & Supports
    Last Post: 27-04-2010, 12:31 PM
  5. FOR SALE: Linear Rail, Carriages & Supports for sale
    By AdCNC in forum Items For Sale
    Last Post: 08-01-2010, 12:27 AM
