Thread: Servo spindle advice
21-09-2021 #1
Hi to all,
I need to cut a 1.7mm stainlees sheet. I have a router (25mm ballscrew on all axes, fogbuster, uccnc 300 eth) with a 2.2 kw spindle with a mechatron changer. I cant cut that with my spindle (not enought torque at lower speeds) and I was thinking to replace the 2.2kw water cooled spindle with a servo. What do you think? Is doable? What kind of servos should I look for? Anybody done that?
Thank you
GabiLast edited by gabi68; 22-09-2021 at 12:22 AM.
21-09-2021 #2
22-09-2021 #3
I can cut it, but is not feasible because ii is taking long time (aka forever). All because of the high RPM's on the spindle. If I do 0.1mm per pass all is good except TIME. I was thinking maybe somebody has a better approach in terms of tooling, speeds and speeds. Did you try that on your Sieg? If so what tooling did you use? Speeds, feeds? TIA
22-09-2021 #4
Anybody ...
22-09-2021 #5
Wouldn't a plasma cutter be the way to go ??
Andrew
22-09-2021 #6
To be honest an 1KW fiber laser will be to right tool for this, but I only have a 50 watt one and the router. Having said that, any other adivices using the router with diffrent tooling, speeds and feeds or maybe a different spindle will be great. Any insights regarding using a servo to replace the spindle.
22-09-2021 #7
What you need is a 4 pole constant torque spindle. These give high torque at low rpm and will cut steel no problem.
We recently started stocking and selling various spindles types from Large ATC spindles down to Constant torque manual tool change spindles. We always test products before committing to stock or use to ensure they are up to the job. So we fit a 4 pole 2.2Kw 24Krpm ER20 water-cooled Constant torque spindle with Ceramic bearings on our own router for testing with a view to offering it as an upgrade from the standard 2.2Kw WC spindles we fit on the machines we build and sell and I must say the power of these spindles has blown me away.
We mostly cut aluminum on this router, which in all honesty is a battered and abused hybrid of a machine that I wouldn't dare show to anyone and this spindle has transformed the machine into a monster that munches aluminum like it's cutting butter.
We have increased the DOC to more than double what the standard 2.2Kw could handle and feed by 50% and getting better tool life because now we can actually cut at recommend tool parameters.
The very first thing we did was cut some mild steel at 5000rpm with an 8mm4F tool @ 2.5DOC which it did without complaint, we always watch the Amps when cutting and they hardly changed and were less than half the rated amps.
The spindles we supply are high quality with GMN Ceramic bearings, balanced rotors using quality wire in the windings with very low runout and quality balanced collet nuts.
Now the downside is they are not cheap at £700 but you get what you pay for, however, these are not the typical spindles you see on eBay or Aliexpress and are made to order. We even have a 40Krpm version.!
Forget the Servo idea unless you have a cartridge-type spindle-like that is fit on milling machines. Just too many obstacles to overcome on a router.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
22-09-2021 #8
Hi Jazz,
I was hoping to chime in. The ATC I have is a Mechatron STC 80. I dont know if that will fit like cartridge-type-spindle. Can you send me some prices for 2.2kw 400Hz, privately?
Thank you
Gabi
ac servo choice/advice
By iamspuddy in forum Lathes, Lathe Rebuilding & ConversionsReplies: 7Last Post: 03-03-2021, 09:07 PM -
servo and spindle advice please
By iamspuddy in forum Stepper & Servo MotorsReplies: 0Last Post: 15-02-2021, 08:10 PM -
Servo as a spindle motor replacement - what to look out for?
By Doddy in forum Stepper & Servo MotorsReplies: 23Last Post: 05-10-2020, 10:34 PM -
2.2kw servo motor for spindle
By blayde in forum Spindles & Drive MotorsReplies: 1Last Post: 01-01-2014, 04:48 AM -
servo as a spindle
By Swarfing in forum Stepper & Servo MotorsReplies: 2Last Post: 27-10-2010, 12:30 AM
