    Hey guys
    I'm looking to build large CNC mainly for plywood cutting - I don't have access to any precision tooling (mills or even drill presses) so the design should be as simple as possible and i was looking at the PrintNC design
    since the plywood sheet is 1220mmX2440mm i was thinking to build it out of 1500mm steel RSTs (100*50*3.2mm) NEMA23 steppers, SFU2010 ball screws and 20mm HIWIN linear rails
    although i upgraded some of the original design components here so it could carry the large dimensions
    now I was thinking to leave some over hang with the RSTs supporting the Y axis (so I could tap some boards vertically)
    could it increase the chance for vibrations? and how to mitigate it ?
    Provided you keep the amount sensible then it won't vibrate, I build machines that hang the tool past the front by 90mm and it doesn't affect them at all.
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
  1. Order of welding for highest chance of success
    By MarcBloke in forum Welding, Brazing & Equipment
    Last Post: 12-01-2021, 09:22 PM
  2. Sieg KX-3 cross (Y) travel increase
    By SteamCAD in forum Sieg Milling Machines
    Last Post: 08-05-2019, 05:23 AM
  3. Vibrations in Chinese 2.2 kW spindle - seek advice ...
    By evalon in forum Generic Chinese Spindles
    Last Post: 25-02-2019, 09:39 PM
  4. Autodesk Fusion 360 $300yr FOR LIFE, LAST CHANCE !!!
    By Lee Roberts in forum Fusion 360
    Last Post: 09-11-2014, 04:08 PM
