    It’s been along time since I did calculations like this so this could be well off !
    I think I would start with the shear modulus of PVC which is 12-115 N/mm2. Let’s take worst case 115N/mm2
    Multiply this by the shear area which is 2x(150x4.5)+2x(100x4.5)
    This assumes a rectangular cookie cutter style blade pressing down with a female tool with the a hole in it supporting the underside of the area to be cut
    This should give the shearing force I think. Try it and see !
    Ps I don’t think the blade width comes into play so long as it can apply the force without bending or damage.
    Happy to be corrected on the above!
    So the calculation comes out at 2250, am I to assume that means 2and a quarter tons pressure?
    The results come out in Newton’s of force required. But please don’t spend money on the outcome of the above calculations because it has been a long time since I did that type of stuff. Ask around and maybe try something out first with what you have to check it is correct.
  1. Table saw blade rising mechanism using cnc parts
    By Radu_Andrei in forum Tool & Tooling Technology
    Last Post: 20-10-2020, 06:48 PM
  2. Replies: 7
    Last Post: 16-11-2019, 04:58 PM
  3. Forces in X,Y and Z
    By PotatoMill in forum Machine Discussion
    Last Post: 10-07-2016, 10:48 AM
  4. Cutting forces at the the tool.
    By Spedley in forum Tool & Tooling Technology
    Last Post: 14-07-2013, 12:04 PM
  5. Calculating forces on linear bearings ...
    By Jonathan in forum Rails, Guideways & Bearings
    Last Post: 24-11-2010, 02:26 AM
