05-10-2021 #2
Yes, the servo will hold the Axis when powered, if it didn't then it wouldn't be much use to you.
The most common way to operate the brake is to simply activate the brake when the Servo drive powers up, usually this is done using a timer relay, so the brake is released a few seconds after the motor energizes. If you activate the brake at the same time as the drive's power up there can be a slight delay before the Motor takes hold and this can cause the axis to drop slightly which in some cases is enough to cause a servo fault.
Without seeing how your control box is setup then can't help much with wiring but it's simple enough, just wire the timer relay so it turns on when the drives turn on, set the timer for 1s or 2s, run the 24V for brake through the Relays NO contacts and after the timer expires it contacts will close and it will release the brake. When the Drives turn off the relay will turn off and the brake will take hold again.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
Using a JMC iHSV57-30-18-36-21-38 servo for z axis without a brake ?
By the great waldo in forum Machine DiscussionReplies: 2Last Post: 22-05-2021, 08:57 PM -
Motors - To Brake or Not to Brake?
By BigBrand in forum Stepper & Servo MotorsReplies: 3Last Post: 14-02-2021, 12:52 PM -
4th axis brake enquiry
By marbles in forum Linear & Rotary MotionReplies: 17Last Post: 12-05-2020, 09:02 AM -
DIY 4th Axis with Brake - The Build
By koenigsegg in forum Milling Machines, Builds & ConversionsReplies: 4Last Post: 03-02-2020, 07:39 PM -
lathe dc servo motor brake/spindle lock ??
By dazza in forum Lathes, Lathe Rebuilding & ConversionsReplies: 0Last Post: 01-11-2014, 05:22 PM
