Thread: X Axis Stall
How frequent does it happen? if frequent enough that you can test and be confident that you should see the problem (e.g. repeat a x-traverse 100 times in g-code), then why not power down disconnect the Y/Z axis and test again - if the problem remains it's not brown-out of the main supply, and you can tick that off your list.
What are your microsteps on the CW8060 set to?
MACH3 hitting soft limits causes X axis to stall
By STK2008 in forum Milling Machines, Builds & ConversionsReplies: 2Last Post: 28-09-2020, 03:44 PM -
stepper motor stall?
By mancave newby in forum Machine DiscussionReplies: 12Last Post: 22-06-2018, 06:59 PM -
em806 Senssorless Stall Protection fault
By charlieuk in forum Motor Drivers & ControllersReplies: 19Last Post: 15-11-2017, 11:36 PM -
Digital Drivers and Stall Detection
By Washout in forum Motor Drivers & ControllersReplies: 6Last Post: 10-12-2013, 05:02 PM -
Y axis is making X axis stall...!!
By fasteddy in forum Machine DiscussionReplies: 83Last Post: 24-10-2011, 12:19 PM
