Thread: jmc 180watt servos any opinions
The holding torque is a weak point, but the speed is a strong point. The size is a weak point (it is very long) but the fact that it has a built in (piggy back) driver and that it has position control is a strong point. It's a compromise, because if you need a lot of holding torque and high speed you need to get a considerably larger, stronger, more expensive and more complicated servo with external drivers. I like it so far where I intend to use it, but won't change my ordinary steppers on my CNC with it. I can be wrong, but I think my steppers are doing a better job than these 180W servo motors could. Anyway, I won't find out, because buying three of these to prove my point (or not) is not worth it. While these are fairly cheap, it's cheaper to use what I have as long as it works for what I do.
AXBB-E any opinions?
By ngwagwa in forum Motor Drivers & ControllersReplies: 12Last Post: 21-07-2021, 04:32 PM -
DMM Servos
By Chaz in forum Motor Drivers & ControllersReplies: 6Last Post: 13-02-2018, 12:16 PM -
Kompas F-3000 Opinions?
By hockinsk in forum Machine DiscussionReplies: 2Last Post: 03-12-2017, 05:24 PM -
new build opinions required
By george uk in forum Gantry/Router Machines & BuildingReplies: 76Last Post: 04-02-2014, 10:46 PM -
Opinions
By p1lts in forum General DiscussionReplies: 8Last Post: 03-02-2011, 08:47 PM
