Thread: Vevor 3018 pro
Hi I have a vevor 3018 Pro. Just started to learn about using this ...and could do with some advice .I was told that it is an engraving machine but I wondered if I could upgrade to a laser cutting machine .thanks for any advice
hello anyone there I really need help with this lolLast edited by Shaggy2023; 21-08-2023 at 10:50 AM. Reason: No response
23-11-2023 #2
Are there any new updates? Is it possible to upgrade to a laser cutter?
27-11-2023 #3
26-10-2024 #4
it sure is possible in fact if you check amazon you can find a couple different lasers and also a 3018 kit that comes with both a wanna b spindle and a low powered laser.
that being said im not sure if it would be worth spending the amount a decent powered lazer to be able to cut, i guess it all depends on what you want to cut if you want to engrave glass, metal and cut thin softer materials i would say go for it but if you want to cut metal i suggest spending the money on a better machine. Now if you are like me and enjoy the process of learning then it is difficult to put a monetary value on what i have learned by spending way too much upgrading and building from scratch machines that ultimately failed.
I hope this helps with your question
VEVOR 0.8KW 220V Air Cooled Spindle Motor CNC setup
By ionapostol in forum Generic Chinese SpindlesReplies: 3Last Post: 08-08-2023, 08:18 AM -
New 3018 Pro problems
By RadioBeamer in forum Chinese MachinesReplies: 4Last Post: 28-05-2020, 09:21 AM -
3018 not moving
By Steve T in forum Chinese MachinesReplies: 1Last Post: 17-04-2020, 07:35 PM -
3018 problem
By bazbalz in forum Machine DiscussionReplies: 8Last Post: 17-12-2019, 12:58 PM -
Vevor 3020 cnc Autolevelling
By iBeta in forum Machine DiscussionReplies: 8Last Post: 22-11-2015, 07:08 PM
