Page 2 of 2 FirstFirst 12
    Hello
    My HY02D223B has also just toasted itself. Before I replace it, does anybody know what the coil resistances should be on a chinese 2.2Kw watercooled spindle?
    Mine all measure around 1.8ohms, does this sound about right?
    Smiffy
    Lives in Marple Stockport, United Kingdom. Last Activity: 12 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,345. Received thanks 618 times, giving thanks to others 87 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by Smiffy View Post
    Hello
    Smiffy
    Yes. Measure between all 3 phases and check that there is no short to the case.
    They usually blow up if the plug comes loose or a short in the plug this is why you should always fix the cable to the Z axis to save it from bending near the plug
    Thank you Clive, Yes all three the same and no short to earth. I'll megger it tomorrow. Cabling installed by builder isn't great, so will redo that now regardless.
  1. HELP no power on my VFD HY02D223B
    By alex wight in forum Generic Chinese Spindles
    Last Post: 13-07-2021, 05:01 PM
  2. Wiring Potentiometer on HY02D223B
    By Lodds in forum Workshop & Equipment
    Last Post: 30-09-2020, 05:54 PM
  3. Huanyang HY02D223B VFD Question
    By iforeman in forum General Discussion
    Last Post: 26-10-2017, 05:00 PM
  4. Wiring Huanyang HY02D223B
    By Stan in forum Milling Machines, Builds & Conversions
    Last Post: 25-03-2017, 07:25 AM
  5. Mach3 Controlling Huanyang HY02D223B 2.2KW VFD
    By Mad Professor in forum Spindles & Drive Motors
    Last Post: 01-10-2016, 10:21 AM
