	13-10-2021 #5Jazz, that looks like a standard wire wound resistor.
 I'd guess it's the residual charge drain capacitor, or possibly the over-voltage dump resistor. I'm also wondering if the relay next to it, is part of the same circuit.
 The blue discs near the main terminals are more like thermistors, but capacitors also come in that kind of package.
 If it was the residual charge drain, I wouldn't expect it to stop the spindle if it had gone pop, which is why I'm wondering if that relay next to it is related, because if the relay had failed, it may cause the resistor to have been connected for longer than it should be.
 If it was for over-voltage, a wiring fault to the spindle might have caused a voltage spike, and caused it to fail.
 Although, I'm wondering how the VFD is being controlled. The high-voltage wiring leaves a lot to be desired, so is the VFD being controlled via the control panel/low voltage terminals, or is it continually being power cycled via the mains input?Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
  HELP no power on my VFD HY02D223BBy alex wight in forum Generic Chinese SpindlesReplies: 3Last Post: 13-07-2021, 05:01 PM
  Wiring Potentiometer on HY02D223BBy Lodds in forum Workshop & EquipmentReplies: 0Last Post: 30-09-2020, 05:54 PM
  Huanyang HY02D223B VFD QuestionBy iforeman in forum General DiscussionReplies: 2Last Post: 26-10-2017, 05:00 PM
  Wiring Huanyang HY02D223BBy Stan in forum Milling Machines, Builds & ConversionsReplies: 21Last Post: 25-03-2017, 07:25 AM
  Mach3 Controlling Huanyang HY02D223B 2.2KW VFDBy Mad Professor in forum Spindles & Drive MotorsReplies: 34Last Post: 01-10-2016, 10:21 AM
