    Hello
    My HY02D223B has also just toasted itself. Before I replace it, does anybody know what the coil resistances should be on a chinese 2.2Kw watercooled spindle?
    Mine all measure around 1.8ohms, does this sound about right?
    Smiffy
    Lives in Marple Stockport, United Kingdom. Last Activity: 14 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,346. Received thanks 618 times, giving thanks to others 87 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by Smiffy View Post
    Hello
    Smiffy
    Yes. Measure between all 3 phases and check that there is no short to the case.
    They usually blow up if the plug comes loose or a short in the plug this is why you should always fix the cable to the Z axis to save it from bending near the plug
  1. HELP no power on my VFD HY02D223B
    By alex wight in forum Generic Chinese Spindles
    Last Post: 13-07-2021, 05:01 PM
  2. Wiring Potentiometer on HY02D223B
    By Lodds in forum Workshop & Equipment
    Last Post: 30-09-2020, 05:54 PM
  3. Huanyang HY02D223B VFD Question
    By iforeman in forum General Discussion
    Last Post: 26-10-2017, 05:00 PM
  4. Wiring Huanyang HY02D223B
    By Stan in forum Milling Machines, Builds & Conversions
    Last Post: 25-03-2017, 07:25 AM
  5. Mach3 Controlling Huanyang HY02D223B 2.2KW VFD
    By Mad Professor in forum Spindles & Drive Motors
    Last Post: 01-10-2016, 10:21 AM
