17-10-2021 #11
Hi Jazz
I got some extra covers for the electronics mounted on the servos that should keep most of the dust out, and i'm going to be ordering lapp screened cable with 0.5mm wire in it. The only thing I have to think about is wether i'm going to need all 10 outs (I don't think so ) as I think dir-pul- and maybe alm or enable 7 wires would do the job the next wire that lapp does 1s 12 core. I still have to run the power +- volts. There doesn't seem to be a ground connection on the servo so it looks like i'll have to make sure the grounding on the frame is solid.
Andrew
correct wiring sizes for JMC Servo iHSV57-30-18-36-21 with axbb-e controller
By the great waldo in forum General ElectronicsReplies: 18Last Post: 31-01-2020, 11:58 PM -
Lichuan "Easy Servo" closed loop stepper question
By Voicecoil in forum Stepper & Servo MotorsReplies: 15Last Post: 09-10-2019, 09:33 PM -
Correct wire for stepper motors??
By RocketBoy in forum General ElectronicsReplies: 3Last Post: 05-07-2016, 10:54 PM -
nema 23's wire colours for bi-polar parallel, can you check this is correct please
By nobby in forum Stepper & Servo MotorsReplies: 2Last Post: 12-06-2013, 01:04 PM -
common wire on stepper motor question
By progomez in forum Motor Drivers & ControllersReplies: 1Last Post: 27-10-2009, 11:56 PM
