Page 3 of 3 FirstFirst 123
  1. #21
    Quote Originally Posted by reefy86 View Post
    what do people put as their machine in fusion 360 if its a diy made one? getting the hang of it and its nice to play with the simulation to get a feel of it rather then testing on the machine which i don't have yet. ill probably be importing a lot of stuff as a stl file because i make my designs else where but so far fusion 360 seems to be easy enough to use
    You should be able to find the correct post processor here.
    https://cam.autodesk.com/hsmposts
    Search for your machine or control software and download the correct one.
    For example I use the CNC Drive post because I have UCCNC on a diy style machine.
    Ollie
  2. #22
    Quote Originally Posted by Ollie78 View Post
    Ollie
    Thank you :)
  3. #23
    Lives in Plymouth, United Kingdom. Last Activity: 20 Hours Ago Has a total post count of 1,748. Received thanks 299 times, giving thanks to others 11 times.
    You can define your own machine anyway. Not that it seems to make a whole lot of difference in most cases. I used to just ignore this setting and did my toolpath generation with no machine specified.
    You can also specify the default post-processor, and also the most valuable thing that I have found - the default Z "Home" position. I don't think that that matters too much with Mach3 as you can define the tool-change position as part of the G28-related parameters, but UCCNC does not handle G28 the same way and you need this to be set up. In fact, I think that this was the driver for me actually setting up a machine definition in the first place as I changed motion controllers in my mill and went from Mach3 to UCCNC. Had a lot of problems with tool-change height and similar until I discovered this.
  4. #24
    Got from etsy in ireland £22.74 worked fine aspire pro10
    have it on zip file
    KEVIN
  5. #25
    Quote Originally Posted by hoopy View Post
    have it on zip file
    KEVIN
    Likely a non legit cracked version that they got for free.
  6. #26
    Hi, I use solidworks for design which now comes with the ability to make tool paths. Also vcurve if it’s a simple part to machine. And the odd bit of fusion360 for gcode.
  1. FOR SALE: Open Build OXCNC for sale, running UCCNC hardware/software.
    By cottomar in forum Items For Sale
    Last Post: 24-10-2019, 09:03 AM
  2. NEW MEMBER: Hello is anyone interested in swapping CNC furniture designs?
    By robgibcnc in forum New Member Introductions
    Last Post: 17-06-2017, 08:39 AM
  3. Comparison between mechanical designs of cnc machines
    By ammaratef45 in forum Machine Discussion
    Last Post: 19-07-2016, 10:48 PM
  4. FOR SALE: Cnc software for sale installed on a pc running xp
    By Kenshamps in forum Items For Sale
    Last Post: 26-10-2014, 11:53 AM
  5. Y-Axis Designs
    By Cyclonit in forum Gantry/Router Machines & Building
    Last Post: 24-06-2014, 02:20 PM
