17-10-2021 #3
Why would you use 12V when it requires 24V.?
If you are powering a 12V relay then you still need 24V for the AXBB-E outputs to work but use the 12V supply for the relay by connecting both 12v and 24V Zero volts together then connecting the 12V + to the relay coil V+ terminal, then run a wire from AXBB-E output you are using to the Relay 0v terminal.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
FOR SALE: some plasma stuff : Neuron Lite Plasma THC and Thermal Dynamics SL100 torch
By Boyan Silyavski in forum Items For SaleReplies: 9Last Post: 10-08-2020, 12:09 PM -
Plasma Torch height setup required
By Yorkshirerapper in forum Artsoft Mach (3 & 4)Replies: 0Last Post: 08-11-2017, 03:26 PM -
Port setup to trigger rely for plasma torch
By whensparksfly in forum Artsoft Mach (3 & 4)Replies: 17Last Post: 15-05-2016, 03:13 PM -
FOR SALE: 3 sets of 4 xl pulleys and a plasma machine torch
By nobby in forum Items For SaleReplies: 0Last Post: 20-05-2014, 07:33 PM -
Plasma, Mach3, Sheetcam and a Proma Torch height controller..
By Davek0974 in forum Plasma Table MachinesReplies: 2Last Post: 14-04-2014, 03:49 PM
