It looks like that is a dedicated, but otherwise conventional 'Z' axis assembly turned on it's side as part of a simple 2 axis machine built just for this purpose. It's not a cunning add-on to an existing gantry router.
I can't see any mechanism to adjust the drilling height to cope with different thicknesses of board but you could do that easily enough with a set of different thickness shims for the drill mounting if you didn't want to go for automatic adjustment of the bed height. Rather than a high speed router spindle you want a drilling motor. Your old mains powered Black & Decker might do the job
Quite an easy machine to build I would say and could use any standard software such as CamBam, Vcarve or Fusion 360 to generate the G-code for it using the standard drilling machine ops. Just use X (or Y) and Z axes as for a normal router. Plus an AXBB-E and a copy of UCCNC of course.An optimist says the glass is half full, a pessimist says the glass is half empty, an engineer says you're using the wrong sized glass.
What version of solidworks is people still using to this day?
By reefy86 in forum General DiscussionReplies: 1Last Post: 01-09-2021, 12:59 PM -
Version 2 of my table
By gr8fun in forum Plasma Table MachinesReplies: 4Last Post: 10-12-2015, 09:10 AM -
g code created for M3, can it be used with EMC2
By deannos in forum Programmers CornerReplies: 3Last Post: 27-08-2012, 08:48 PM -
Version 0.1
By SirMorris in forum Gantry/Router Machines & BuildingReplies: 8Last Post: 16-06-2008, 08:33 PM -
BUILD LOG: Version 0.1
By SirMorris in forum DIY Router Build LogsReplies: 7Last Post: 11-08-2007, 02:52 PM
