21-10-2021 #21
There's a few issues with their code. There is no clamp. I also do not have both forward and reverse, I can only move the turret in one direction.
Whereas the logic is simpler. My turret down detect switch doesnt seem to work, so its not wired in at the moment.
On Tool Change request (if tool doesnt match current tool), then activate an output (On Solenoid).
Keep this output on until the correct tool number is matched (this is via the 4 bit logic defined in CASET)
Then, as soon as the Toolnumber is correct, activate a 2nd output (which is the stop solenoid)
This is not the same as switching off the on solenoid. The stop solenoid actually pushes out an arm to 'stop' the turret in the right location.
It then switches off the 'on solenoid' which lowers the turret
The turret then is detected by a switch
The stop solenoid can now be turned off. Tool Change done.
M63 comes on as defined in the code, then it stops when it detects 'something' but not sure what. Certainly taking out the +X07,T07 will probably help. I need to understand where X07 is defined. T07 is probably the T07 they refer to in their instructions (input, position of unlock turret). Not sure where +X07 is defined, nor X06 for that matter.
They also use Y18 and Y19, but not sure what those are.
21-10-2021 #22Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
21-10-2021 #23
OK, I found an IO Mapping text document in the backed up files. So my assumptions were correct.
T01 X00
T02 X01
T03 X02
T04 X03
T05 X04
T06 X05
T07 X06
T08 X07
+T Y18
-T Y19
Noted you have replied, thanks. Yes, the problem is lack of tool location detection. In the I/O screen I can see the 4 bits change. There is a 'phase' where they read all 1 1 1 1 as the hall sensor goes from one state to the next but there is no defined 1 1 1 1 so it should ignore this.
Question is, why does it not translate inputs it can clearly see into what the screen shows. I thought it might be as its not declared early enough and it never gets that far in the code, moved it up, no difference.
21-10-2021 #24
I'm going to rewrite the code and take out all the stuff which is clearly not needed, maybe that allows the code to be read for the location.
21-10-2021 #25
I'm using M69 output to enable the Stop Solenoid.
PAUS100
STAF(Rotating Turret!)
OUT+M63;unclamp
STAF(Rotate & Select Tool!)
CASET1+X00-X01-X02+X03
CASET2-X00+X01-X02+X03
CASET3+X00+X01-X02+X03
CASET4-X00-X01+X02+X03
CASET5+X00-X01+X02+X03
CASET6-X00+X01+X02+X03
CASET7+X00+X01+X02-X03
CASET8-X00-X01-X02+X03
PAUS50
STAF(Location Found, Lower Turret!)
OUT+M69
STAF(Stop Engaged!)
PAUS250
OUT-M63
OUT-M69
TS(0)=TAIM
CURTS=TAIM
STATUSINFO(Tool Change is Finished!)
PAUS300
DISP
RETURN
21-10-2021 #26
What I'd probably do, is start with a basic custom macro to test tool positions.
Something like -
IF(+X00-X01-X02+X03)THEN
MESSAGEBOX(TOOL 1)
RETURN
ENDIF
Make sure the turret is on position 1, the relevant inputs are as expected, run the macro, and see if you get the message shown.
If the message doesn't show, try just the MESSAGEBOX with a basic message to ensure the macro is actually running (or try this first to save some typing!)
You could then extend the macro for other tool positions, and add in TS(0) = xx, CURTS = xx, and DISP to initialise the tool position.
Once you know you can read the tool positions correctly, then work on getting the turret to move.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
21-10-2021 #27
Some progress. It now updates tool location as I've removed the wrong code. Can't get it to activate the stop sol however. Still looking.
21-10-2021 #28
Thanks. Ive got it working !!!!
Many thanks for your help.
So a few issues.
Their code wasnt right for my machine. So the logic never got to the point of updating the tool (plus I had to redo the 4 bit logic as I had their original version).You also cant use any output here, M69, M67, none worked (Yet M63 does ....).
I then used the Turret + assigned to the Stop Solenoid, that worked. Then it was just a case of getting the timings right.
Vid of it working to follow.
Next will be setting up tool offsets etc.
Many thanks once again.
21-10-2021 #29
I'd guess macros are limited as to what other macros they can call, to avoid locking things up.
There is probably some page in a manual somewhere that lists what you can, or can't do, and it may never even have been translated to English.
I know the section of the manual for my lathe controller covering the polygonal turning, was a fresh translation, as there was even a note on the front page requesting what pages were to be translated from the original Chinese manual.
Lathe tool offsets can be fun.
I've only recently thought about how to do mine better, as some new parts I'll be making require a bit more accuracy between tools.
My plan is to use a 50mm height gauge (the dial type you get for setting tools on mills), to set the tools 50mm from the face of the chuck, then adjust part offsets accordingly.
Off course, if you'll be using different chucks, then that won't work very well.
If you don't need high accuracy, then you can just set tools relatively to each other by facing a bit material, then jogging onto the freshly faced surface with a new tool, which will usually get you within 0.02mm accuracy if you're careful.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
21-10-2021 #30
There are currently 17 users browsing this thread. (0 members and 17 guests)
Has anyone got any experience of SheetCNC or UK-DIY CNC?
By OceanMachine in forum Gantry/Router Machines & BuildingReplies: 10Last Post: 30-04-2021, 03:59 PM -
anyone had any experience of these cl motors
By alboy in forum Stepper & Servo MotorsReplies: 1Last Post: 21-08-2018, 11:23 AM -
Anyone had experience with one of these Coolubricators...
By Wal in forum Swarf & Chip ManagementReplies: 4Last Post: 06-04-2014, 02:16 PM -
By Wal in forum Marketplace DiscussionReplies: 0Last Post: 06-02-2014, 01:07 AM -
EXPERIENCE: XYZ Machine - My Experience
By David Maybury in forum Trading Experience & FeedbackReplies: 0Last Post: 03-12-2012, 11:04 AM
