    I'm in the San Diego area of Southern Calif.
    I program CNC machines for GKN (you might recognize GKN) aerospace here in El Cajon.
    I make stuff from wood and metal "bits" ().
    Decided to make myself a horizontal mounted CNC router to make dovetail corners, mortise-tenon joints and a little general routing.
    I bought stepper motors/drives/power supply as a kit from Ebay, need to source a breakout board, ways and lead screws still. Will use Mach3 maybe 4 to control it. (Must be USB, parallel ports have gone the way of the Dodo). Oh, and the frame will be 1.25 11ga sq tube (roughly 32mm 3mm wall for the metrically inclined)
    Just completed a 2 axis plasma table I bought online from Langmuir Systems. Had some issues with the lead screws but I think that has been resolved. It was a good starter for my CNC router project.
    Glad I found the group.
    Fred
    Welcome to the forum Fred. Sounds like you have some useful experience to offer.
    Kit
    Nah Parallel Ports are still are viable option for Linuxcnc. All you have to do is have a look on the Linuxcnc forum for recommended PCIe cards. Tho the Mesa FPGA cards are a far better alternative. Linuxcnc still will do the trajectory planning and the FPGA cards handles the step & direction timing, I|O and encoders.
    Lives in Marple Stockport, United Kingdom. Last Activity: 16 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by BeagleBrainz View Post
    These work fine https://www.ebay.co.uk/itm/254930870...5fa1b1072eb21c
    Quote Originally Posted by Fred101 View Post
    Must be USB
    No, why?.
    USB can be problematic from the emi noise given off by vfd drives if you use one.
    You waant an Ethernet controller like a Smoothstepper or UC400eth.
    I used that one . I think I have a spare too
    Quote Originally Posted by John11668 View Post
    I actually bought 5 in a batch for £25 all used but all worked fine
  1. NEW MEMBER: Hello from the other side of the pond.
    By Sunrazor in forum New Member Introductions
    Last Post: 30-09-2020, 08:50 PM
  2. NEW MEMBER: From across the pond.
    By 87bob in forum New Member Introductions
    Last Post: 03-08-2014, 12:55 PM
  3. NEW MEMBER: Hello for across the pond.
    Last Post: 01-08-2014, 09:05 PM
  4. RFQ: Gantry side panels
    By fvfdrums in forum Projects, Jobs & Requests
    Last Post: 17-01-2014, 03:50 PM
  5. NEW MEMBER: New Member from Across the Pond-and an Introduction to My CNC Lathe Project
    By acollins in forum New Member Introductions
    Last Post: 13-05-2012, 10:14 PM
