    Lives in East Lothian, United Kingdom. Last Activity: 13 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    Since nobody seems to want to buy my old lathe due to it's current dual voltage setup, I'm thinking about changing it so it runs solely of 240V.
    The spindle is easy enough to sort, but the turret is more of a problem.
    It uses a 600W 3 phase 110V motor, which is currently powered via a 3 phase 415->110V transformer, then two interlocked contactors for forward/reverse.
    If I was to power it with a VFD, am I correct in thinking, all I need to do is change the rated motor voltage setting in the VFD from 230V, to 110V?
    Chaz's Avatar
    Not sure about that. In my experience (limited), the VFD's voltage output is pretty much set. For example in my 9100 VFD, they offer some tuning of the output but its like 380-410, not anything that would allow me to half the voltage.
    That said, why not try one, set it down 110V and use a dummy load and measure what it outputs.
    Are you sure that's the reason it isn't selling? The way I see it, you are proposing to spend money to replace a perfectly acceptable and well understood method of powering the 110V motor with something which is probably less reliable, more complex and difficult to replace or fault-find at a later date.
    Kit
    VFDs vary voltage according to frequency, so at below motor rated speed, they're reducing voltage anyway, it's just that I'm not sure it'll be as simple as changing a single parameter.
    If I had a standard VFD surplus, I would try it and see, but I've not just now.
    I've had a couple people interested, but they've not had access to 3 phase, which is why I'm thinking about changing it.
    Currently it needs 3 phase for the spindle and turret, and single phase for the controller and servos.
    I am considering keeping it, as it can do things it's replacement can't, but I would like to simplify how it's powered regardless.
    For some reason I failed to notice that this is a 3-phase motor even though you wrote that twice! Must press the 'ON' button on my brain before writing comments in future!
    Kit
  1. 110v 3 phase for baruffaldi turret
    By jonnydeen in forum Motor Drivers & Controllers
    Last Post: 06-09-2020, 11:48 PM
  2. Replies: 21
    Last Post: 19-01-2017, 01:49 PM
  3. Porter Cable 75182 Router on 110V site transformer.
    By James123 in forum Porter Cable Routers
    Last Post: 19-11-2014, 05:42 PM
  4. motor power and chinese spindles power HELP
    By DigiSoft in forum Spindles & Drive Motors
    Last Post: 17-09-2013, 12:17 AM
  5. Stepper Motor Power Question
    By boldford in forum Gantry/Router Machines & Building
    Last Post: 17-07-2012, 09:40 AM
