Page 2 of 7 FirstFirst 1234 ... LastLast
  1. You don't always need a crossover network cable, a lot of network cards will do it automatically.
    Sent from my COL-L29 using Tapatalk
    Quote Originally Posted by Cube3 View Post
    With the AXBB-E and Static IP you do.
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
    Same with the UC300eth (same controller base as the AX).
    Pretty much guarantees it's going to work.
    Ordered the AXBB-E today, so looking forward to recieving and having a go setting it up, will post pics of the insides of the controller box i have tomorrow so people can tell me what i need and dont need and give me any help i need installing new card.
  5. The network card does the crossover automatically. You can use a normal patch lead IF your network card supports this function. We'll at least that's my setup.
    I think the network option is called Auto-MDIX
  6. The Following User Says Thank You to Cube3 For This Useful Post:
  7. #6
    Many do, yes. Likely get the odd packet loss which is not good for cnc even if slight.
    However, why bother arguing with the user manual?.
    It says use crossover when connected direct so why not do it?.
    Not exactly expensive.
    I made one from some cat7 bits I had.
    Carefully set it all up and was moving in no time.
  8. #7
    This is what i have, what do i need and what do i have to take out....cheers
ID:	30856Click image for larger version.
ID:	30857Click image for larger version.
ID:	30858Click image for larger version.
ID:	30859Click image for larger version.
    Just received my AXBB-E and i also got a 5v and 24v psu so all i need to do now is panic as i dont have a clue what im doing......Help
ID:	30861 do i keep this board as it has the X Y Z axis attached
    UPDATE.....Have connected Axbb-e to the 5v and 12v power psu and also connected network, so now need to build a bigger controller box so all will fit in.
  9. #8
    Quote Originally Posted by mrmacca View Post
    That is an all-in-one board with controller and motor drives combined so you can't use it because you can't control the drives.
    To use with the AXBB-E you will need separate drives.
  10. #9
    Cheers Jazz ...will have a look about and order some.
  11. #10
    My stepper motor has this on it NN MOTOR 57HS7416-15-14B 80 Does that mean anything , when I did a search it didn't come back with much except nema 23, so do i order drivers for a nema 23.
  1. Z axis out by 2mm mach3 or fusion360 problem?
    By Richardtweed in forum Machine Discussion
    Last Post: 01-05-2022, 08:41 PM
  2. Mach3 lathe spindle pulleys problem
    By John11668 in forum Artsoft Mach (3 & 4)
    Last Post: 30-01-2021, 03:04 PM
  3. Small Mach3 Problem
    By needleworks in forum General Discussion
    Last Post: 11-05-2020, 10:46 AM
  4. Mach3 & V-Carve Problem
    By Ricardoco in forum Computer Software
    Last Post: 31-05-2013, 12:53 PM
  5. Mach3 small problem
    By dudz in forum Artsoft Mach (3 & 4)
    Last Post: 15-11-2012, 05:56 PM
