Page 3 of 7 FirstFirst 12345 ... LastLast
    Quote Originally Posted by mrmacca View Post
    My stepper motor has this on it NN MOTOR 57HS7416-15-14B 80 Does that mean anything , when I did a search it didn't come back with much except nema 23, so do i order drivers for a nema 23.
    Depends on what you want to do and the motor spec. Model number not showing anything so double check you have it right.
    What are it's dimensions, that may also give us a clue on it.
    Personally, I never run my nema23 motors below 60vdc anymore which requires the nema34 drivers DM860T instead. The velocity you can achieve is so much better.
  2. The Following User Says Thank You to dazp1976 For This Useful Post:
  3. #2
    This is typical of Chinese machines as they fit oddball motors which you probably won't find any info about. However, doesn't really matter too much because you will only have at best 36Vdc from the PSU so any drive with a 50Vdc max rating will work for you. Because you can't tell the motor current a little trial and error will be needed on the amps but this is no big deal as they will just run hot if too high and stall easily if too low.
    These will work fine for what you need and will work miles better than what you had before. But before buying it's worth checking the voltage coming from the PSU
    https://www.omc-stepperonline.com/di...or-dm542t.html
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
    Ordered. Cheers
  5. #4
    Ordered. Cheers
    If you find that your max velocity is below what you would like, swap out the 36v for a 48v.
    I'd have gone for the DM556:
    https://www.omc-stepperonline.com/di...scription=true
  6. The Following User Says Thank You to dazp1976 For This Useful Post:
  7. #5
    I use DM542T drivers at 36V on a pair of 3NM NEMA23 motors to pull an 800mm wide welded steel gantry with a 2.2KW spindle on it. It's fairly weighty but will rapid at over 10/min with reasonable acceleration so they'll probably do.
    However, there is always a case for spending a bit more on something over-specified for your present needs if you might want to upgrade other parts in the future. It's a balance between spend more now to save in future.
    To get a bit more info on the motors you could look at the spec of similar sized motors from stepperonline and others. Measure the winding resistance of the motors you have and look for a match in both resistance and physical size. It's not a guarantee they're the same current rating but will give you somewhere to start.
  8. The Following User Says Thank You to Kitwn For This Useful Post:
  9. #6
    Hi All,
    been having a go at building onto the AXXB-E attached are some pics and would like advice as to were I have gone wrong on the stepper drives, also the 3 wires lying by the AXXB-E are from the VFD av1 grnd and +10v were do i attach these to the AXBB-E, also emergency stop and pump.
    All the advice i have had up to now is much appreciated.
ID:	30872 Click image for larger version.
ID:	30873 Click image for larger version.
ID:	30874 Click image for larger version.
ID:	30875 Click image for larger version.
  10. #7
    Hi All,
    Be Careful if you don't know what you are doing because you can easily damage the controller if you connect up wrong. Don't turn it on until you are 100% sure it's correct, you can't afford to use a trial and error method here because you won't get a second chance once you let out the magic smoke.
    I will knock you up some simple diagrams but it will be tomorrow now, I suggest you wait rather than have a go without being sure.
  11. #8
    Ok, here you go. I have broken each down into separate drawings.
    On the VFD you don't need the 10V with AXBB so just remove the wire.
ID:	30877Click image for larger version.
ID:	30878Click image for larger version.
    Edit: My drawings show Step which is Puls on your drives.
  12. #9
    Cheers Jazz,
    no would not have turned it on and still wont till im sure , thats why i asked for help lol.
    Actually had another read of the manual and spotted where I have gone wrong.
    Cheers M8
  13. #10
    Lives in Plymouth, United Kingdom. Last Activity: 21 Hours Ago Has a total post count of 1,748. Received thanks 299 times, giving thanks to others 11 times.
    Looking at the first two images, I'm concerned about the polarity of the supply to the stepper driver. It appears to show a black wire to +ve and red to -ve, although the 24V supply to the AXBB is correct. I can't see where these wires go on the power supply.
  1. Z axis out by 2mm mach3 or fusion360 problem?
    By Richardtweed in forum Machine Discussion
    Last Post: 01-05-2022, 08:41 PM
  2. Mach3 lathe spindle pulleys problem
    By John11668 in forum Artsoft Mach (3 & 4)
    Last Post: 30-01-2021, 03:04 PM
  3. Small Mach3 Problem
    By needleworks in forum General Discussion
    Last Post: 11-05-2020, 10:46 AM
  4. Mach3 & V-Carve Problem
    By Ricardoco in forum Computer Software
    Last Post: 31-05-2013, 12:53 PM
  5. Mach3 small problem
    By dudz in forum Artsoft Mach (3 & 4)
    Last Post: 15-11-2012, 05:56 PM
