    Must be blind i cant find it
    Quote Originally Posted by mrmacca View Post
    Vfd Wiring diagram is on this page:
    http://whzoncn.com/m/view.php?aid=83
    You can see the loop and the break of the switches.
    (ignore the 0-10v,, it's showed for pot use).
    Mach3 plugin here:
    https://www.cncdrive.com/AXBB.html
    It's the ucx00 auto installer file.
    The jumper is inside the AXBB-E top cover.
    Easy way to test first is if you midi M3S24000 and the max the spindle spins is only around 12000rpm then it is likely jumper set as 5v (half speed).
    UNLESS.... Your spindle full speed is less than 24k. If so, set full speed in midi and see if you get half or full rpms.
There are currently 38 users browsing this thread. (0 members and 38 guests)
  1. Z axis out by 2mm mach3 or fusion360 problem?
    By Richardtweed in forum Machine Discussion
    Last Post: 01-05-2022, 08:41 PM
  2. Mach3 lathe spindle pulleys problem
    By John11668 in forum Artsoft Mach (3 & 4)
    Last Post: 30-01-2021, 03:04 PM
  3. Small Mach3 Problem
    By needleworks in forum General Discussion
    Last Post: 11-05-2020, 10:46 AM
  4. Mach3 & V-Carve Problem
    By Ricardoco in forum Computer Software
    Last Post: 31-05-2013, 12:53 PM
  5. Mach3 small problem
    By dudz in forum Artsoft Mach (3 & 4)
    Last Post: 15-11-2012, 05:56 PM
