Thread: step and dir pulse problem Mach3
I didn't mean altogether. I said they were Parallel.
Should have been clear on 'using only what you need'.
Gave the VFD wiring diagram/manual showing how it was a loop style circuit. Each one individually switched
Wasn't sure if AXBB-E was preset to 10v out. That's why I said test max speeds first to see if you get 100% or 50%.
If you're going to dabble in cnc, you NEED to be able to at least read a wiring diagram.
Your diagram in post #61 shows how the relay on the output activates the loop circuit for fwd on the vfd as I said.
Relay connections on outputs is covered in AXBB-E manual. VFD switch connections are covered in it's manual.
There has been more than enough diagrams put out.Last edited by dazp1976; 25-02-2022 at 11:41 PM.
25-02-2022 #2
changed active low and it still does the same, if i keep my finger on up the spindle goes as far as it can go the comes down, goes as far as it can go then goes back up.
And Daz yes lots of diagrams put out thanks to Jazz and I hope he puts more out to help me get this sorted, I don't mind asking for help because I don't understand it, But maybe I might learn with all the help I'm getting.....Oh one more question , what colour is the live in a plug.
Thank you and goodnight.
26-02-2022 #3
26-02-2022 #4-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
26-02-2022 #5
Hahaha taking the mick , sorted the Z axis it was a loose connection , so all i need to do is sort probe and e-stop out.
Also Jazz the 10v on the vfd does that need a wire going from it to anywhere.
Many Thanks.
26-02-2022 #6
No.
The vfd 10v is to give power to a manual 3 pin potentiometer. Then the pot dial adjusts that voltage and sends it back into the avi input via the wiper based on where you position the dial. Then it has a 3rd wire that goes to gnd .
That's how that one works.
If you did want to add a manual pot you can use the analog inputs on the axbb-e.
There are 2 on it so you could manually override both the spindle rpm and the feedrate using the wiper wire on a 3 pin dial if wanted.
I'm doing this on my 300eth.
Glad you figured the Z out.Last edited by dazp1976; 26-02-2022 at 06:40 PM.
The Following User Says Thank You to dazp1976 For This Useful Post:
04-03-2022 #7
The Following User Says Thank You to mrmacca For This Useful Post:
Z axis out by 2mm mach3 or fusion360 problem?
By Richardtweed in forum Machine DiscussionReplies: 21Last Post: 01-05-2022, 08:41 PM -
Mach3 lathe spindle pulleys problem
By John11668 in forum Artsoft Mach (3 & 4)Replies: 32Last Post: 30-01-2021, 03:04 PM -
Small Mach3 Problem
By needleworks in forum General DiscussionReplies: 8Last Post: 11-05-2020, 10:46 AM -
Mach3 & V-Carve Problem
By Ricardoco in forum Computer SoftwareReplies: 2Last Post: 31-05-2013, 12:53 PM -
Mach3 small problem
By dudz in forum Artsoft Mach (3 & 4)Replies: 7Last Post: 15-11-2012, 05:56 PM
Night.
