    Quote Originally Posted by mrmacca View Post
    My stepper motor has this on it NN MOTOR 57HS7416-15-14B 80 Does that mean anything , when I did a search it didn't come back with much except nema 23, so do i order drivers for a nema 23.
    Depends on what you want to do and the motor spec. Model number not showing anything so double check you have it right.
    What are it's dimensions, that may also give us a clue on it.
    Personally, I never run my nema23 motors below 60vdc anymore which requires the nema34 drivers DM860T instead. The velocity you can achieve is so much better.
  2. The Following User Says Thank You to dazp1976 For This Useful Post:
There are currently 39 users browsing this thread. (0 members and 39 guests)
  1. Z axis out by 2mm mach3 or fusion360 problem?
    By Richardtweed in forum Machine Discussion
    Last Post: 01-05-2022, 08:41 PM
  2. Mach3 lathe spindle pulleys problem
    By John11668 in forum Artsoft Mach (3 & 4)
    Last Post: 30-01-2021, 03:04 PM
  3. Small Mach3 Problem
    By needleworks in forum General Discussion
    Last Post: 11-05-2020, 10:46 AM
  4. Mach3 & V-Carve Problem
    By Ricardoco in forum Computer Software
    Last Post: 31-05-2013, 12:53 PM
  5. Mach3 small problem
    By dudz in forum Artsoft Mach (3 & 4)
    Last Post: 15-11-2012, 05:56 PM
