Thread: step and dir pulse problem Mach3
Vfd Wiring diagram is on this page:
http://whzoncn.com/m/view.php?aid=83
You can see the loop and the break of the switches.
(ignore the 0-10v,, it's showed for pot use).
Mach3 plugin here:
https://www.cncdrive.com/AXBB.html
It's the ucx00 auto installer file.
The jumper is inside the AXBB-E top cover.
Easy way to test first is if you midi M3S24000 and the max the spindle spins is only around 12000rpm then it is likely jumper set as 5v (half speed).
UNLESS.... Your spindle full speed is less than 24k. If so, set full speed in midi and see if you get half or full rpms.Last edited by dazp1976; 25-02-2022 at 09:03 PM.
Z axis out by 2mm mach3 or fusion360 problem?
By Richardtweed in forum Machine DiscussionReplies: 21Last Post: 01-05-2022, 08:41 PM -
Mach3 lathe spindle pulleys problem
By John11668 in forum Artsoft Mach (3 & 4)Replies: 32Last Post: 30-01-2021, 03:04 PM -
Small Mach3 Problem
By needleworks in forum General DiscussionReplies: 8Last Post: 11-05-2020, 10:46 AM -
Mach3 & V-Carve Problem
By Ricardoco in forum Computer SoftwareReplies: 2Last Post: 31-05-2013, 12:53 PM -
Mach3 small problem
By dudz in forum Artsoft Mach (3 & 4)Replies: 7Last Post: 15-11-2012, 05:56 PM
