    RobC's Avatar
    Lives in Leeds, United Kingdom. Last Activity: 10-04-2026 Has been a member for 8-9 years. Has a total post count of 118. Received thanks 16 times, giving thanks to others 21 times.
    Hello all.
    I'm trying to identify the correct values for this capacitor. It's a 2 spade pin capacitor from a motor on a compressor I acquired and I'm trying to get it back to a fit state to use. There's so many out there but they are 4 pins and I don't want to fit the wrong one.
    Rob
    Lives in East Lothian, United Kingdom. Last Activity: 1 Hour Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    You're going to have to do some guess work, as it looks like the capacity and voltage markings have worn off.
    I'd guess there are probably guides for capacitor sizing if you know the rating of the motor.
    The number of connectors won't make any difference to how it functions, as 4 spades just means each of the terminals has two connectors.
    RobC's Avatar
    So its a 2hp motor. Would a 240v 500-580 µF be the correct one for it?
    Quote Originally Posted by RobC View Post
    40-50 uf should do the job. Don't forget to get the voltage right.
    Cheers.
    Andrew
    Sent from my XT1580 using Tapatalk
  1. Help with identifying fitting please :)
    By Fivetide in forum General Electronics
    Last Post: 01-02-2021, 12:27 AM
  2. Replies: 4
    Last Post: 14-07-2019, 01:19 AM
  3. Identifying Steel types.
    By cambesol in forum Metalwork Discussion
    Last Post: 10-12-2013, 10:26 AM
  4. Help identifying a tool?
    By jonbabbz in forum Tool & Tooling Technology
    Last Post: 27-04-2012, 10:01 PM
