    Slow progress but lots of fun...
    Problem: The oil fed slide Z axis is so overloaded by motor overhang it cannot be relied on to move down tiny distances.
    Solution: Replace the slide with profile rails.
    Problem: If I make it any thicker/wider my 612 will quickly turn into a 611. I am limited to 1/2" steels and 20mm rails.
    Picture shows profile rails next to original dovetails. Square shows I have lost about 3mm. Would have been 5mm but I sank the rails 2mm down into the plate to keep them square.
    Now I have to trim the ends off the rails. I think I may be able to band saw it? These are not pukka rails, these are a £44 for two with 2 extra carriagesblocks, Chinesium special. If I hit the end with a file it cuts.
    Good thing about a 20mm rail is that you can fix it down with 6mm cap heads, if you don't mind reducing the head diameters by 0.6mm
    Thanks for listening
    Robin
    Can you cut a cheap, 20mm, profile rail with a bandsaw?
    Let's find out
    http://www.robinhewitt.net/CutRail.mp4
    Let's find out
    It will cut very easily with a 1mm 110mm disc
    Angst. Dropped the blooming thing, luckily onto floorboards rather than concrete.
    Broke a plastic wiring box cover and bent the ball screw.
    Still time to shop before Xmas, £16 for a new screw, jolly annoying though
  1. Old Capco Surface Grinder restoration!
    By Ancient-Axeman in forum Workshop & Equipment
    Last Post: 06-12-2020, 09:01 PM
  2. DIY Surface grinder
    By Robin Hewitt in forum General Discussion
    Last Post: 11-11-2018, 12:33 PM
  3. Surface Grinder - Elliott 618 - Any Good?
    By Chaz in forum Metalwork Discussion
    Last Post: 30-08-2018, 01:51 PM
  4. NEW MEMBER: From grinder to 3D printing to CNC
    By laranjas3 in forum New Member Introductions
    Last Post: 12-10-2017, 06:59 AM
