    Quote Originally Posted by jolyonjenkins View Post
    Hello
    Can someone help me with the wiring of a Sprint 400 driver board. The manual is here
    https://www.sprint-electric.com/wp-c...0_1200-web.pdf
    I want to connect it to the spindle on my Denford Micromill. The datasheet gives 4 outputs, two as "armature" and two as "field". I have to admit that I don't really know what these mean or how to identify the four on the spindle. However, when I apply mains power to the board, there is 0V on the "armature" pair, and 200V DC on the "field" pair. If I connect the 10V reference on pin 1 to the input on pin 3, nothing changes. What I need is for the DC output to go from 0 to 90V (the spindle maximum). Would appreciate some guidance
    Something sounds amiss. Did you blow yours up or was the drive not supplied in the first place???.
    I can't see it happoening myself. The 0-90v units look like they run off 115vac input. (u.s. ver input)
    On 230vac input they give you 0-180v (looks like this is what you are finding). (u.k. ver input)
    PLEASE NOTE:
    There is only one board that puts out 0-90v on a 230vac input and that is the:
    KBIC-240DS
    This is extremely likely the one you need.
    https://www.axiscontrols.co.uk/produ...eed-controller
    Who put you onto the sprint???.
    The sprint is for the 180v motor types that exist, or the u.s. 90v types.
    The official boards are these by the looks of it:
    https://www.kbelectronics.com/data_sheets/kbic_oem.pdf
    http://www.kbelectronics.com/data_sheets/kbic.pdf
    (sounds like the motor would be the u.s. standard one and they threw a quick fix board in for u.k voltages if you weren't given the control).
    There's 3 options here.
    1. you find a 180v motor for it.
    2. have to resort to the buying the KB control board.
    3. get 115Vac input to the sprint 400.
    Quote Originally Posted by dazp1976 View Post
    I can't see it happoening myself. The 0-90v units look like they run off 115vac input. (u.s. ver)
    On 230vac input they give you 0-180v (looks like this is what you are finding). (u.k. ver)
    PLEASE NOTE:
    KBIC-240DS
    (Initially the motor would be the u.s. standard one and they threw a quick fix board in for u.k voltages). Because it was cheaper!.
    I might have blown mine up. There was a cascade of errors which led to me basically replacing a lot of the electronics.
    I got a second hand board from ebay. It looks identical to the original board, and identical to the ones that I've seen in photos of other Denford micromills. The sprint board has a jumper which lets you set the input voltage to 230V (or 110V) so I'm not sure why you think I need the KB driver.
    Your pdf has a typo. This is the proper one:
    https://www.transdrive.co.uk/media/1...200-manual.pdf
    The sprint 400 is: 110/240 = 90/180
    So: 110v = 90v and 240 = 180v
    The switch is just an input voltage selector like on a meanwell power supply.
    However. Unlike a meanwell, a speed control is relative to it's input.
    So if it gets 240v it'll put out 100%. If it gets 110v it'll only put out 50%.
    Ergo 180/90.
    Unless you have the actual 180v version motor for it I'm afraid you likely need the KB.
    (basically a bodged voltage board worked out cheaper to get u.k. sales)
    Yours may look the same to others but they'll likely have the 180v motor too.
    Like this:
    https://www.ebay.com/itm/393622606533
    I may have updated previous post too while you responded.
    Ergo 180/90.
    Like this:
    Ah, this might explain why I can only get 100V out of it. Hmm. There do seem to be fairly cheap PWM DC-DC controllers on Ebay which I could maybe bolt on
    Did you have it running before?.
    Did you plug it in and pretty much blow the lot by any chance?.
    Everything I look into so far is showing me schematics with 110v input.
    This suggests to me that there should be a 220v-110v transformer in there for use with u.k. supply.
    Okay so. From what I said previously.
    On this Denford data page in the 4th post down:
    https://www.denfordata.com/bb/viewtopic.php?f=36&t=2929
    The schematic shows the 'power transformer' which converts u.k. 240vac into 110vac for the machine.
    Micromill-electrical-feb-2000.pdf
    https://www.denfordata.com/bb/download/file.php?id=2796
    Micromill-denstep-electrical-June2000.pdf
    https://www.denfordata.com/bb/download/file.php?id=2795
    Look for this in your machine. Could be the overall culprit.
  1. Boxford 160 TCL -Lenze 534 DC motor Driver Board
    By JohnnyK in forum General Electronics
    Last Post: 01-09-2021, 10:22 AM
  2. Sprint 400i DC motor controller wiring
    By Ross77 in forum Spindles & Drive Motors
    Last Post: 16-09-2017, 09:19 PM
  3. Driver and board recommendations
    By sternfox in forum Motor Drivers & Controllers
    Last Post: 25-09-2016, 08:16 PM
  4. WANTED: Routout CNC Driver Board 2.5 amp Single
    By fozziebear40 in forum Items Wanted
    Last Post: 29-03-2012, 07:36 PM
  5. New SCR driver board, or new motor & VFD?
    By m_c in forum Motor Drivers & Controllers
    Last Post: 04-11-2010, 05:16 PM
