    Quote Originally Posted by dazp1976 View Post
    Something sounds amiss. Did you blow yours up or was the drive not supplied in the first place???.
    I can't see it happoening myself. The 0-90v units look like they run off 115vac input. (u.s. ver)
    On 230vac input they give you 0-180v (looks like this is what you are finding). (u.k. ver)
    The official boards are these by the looks of it:
    https://www.kbelectronics.com/data_sheets/kbic_oem.pdf
    http://www.kbelectronics.com/data_sheets/kbic.pdf
    https://www.axiscontrols.co.uk/produ...eed-controller
    PLEASE NOTE:
    There is only one board that puts out 0-90v on a 230vac input and that is the:
    KBIC-240DS
    This is extremely likely the one you need.
    (Initially the motor would be the u.s. standard one and they threw a quick fix board in for u.k voltages). Because it was cheaper!.
    There's 3 options here.
    1. you find a 180v motor for it.
    2. have to resort to the buying the KB control board.
    3. get 115Vac input to the sprint 400.
    I might have blown mine up. There was a cascade of errors which led to me basically replacing a lot of the electronics.
    I got a second hand board from ebay. It looks identical to the original board, and identical to the ones that I've seen in photos of other Denford micromills. The sprint board has a jumper which lets you set the input voltage to 230V (or 110V) so I'm not sure why you think I need the KB driver.
    Quote Originally Posted by jolyonjenkins View Post
    Your pdf has a typo. This is the proper one:
    https://www.transdrive.co.uk/media/1...200-manual.pdf
    The sprint 400 is: 110/240 = 90/180
    So: 110v = 90v and 240 = 180v
    The switch is just an input voltage selector like on a meanwell power supply.
    However. Unlike a meanwell, a speed control is relative to it's input.
    So if it gets 240v it'll put out 100%. If it gets 110v it'll only put out 50%.
    Ergo 180/90.
    Unless you have the actual 180v version motor for it I'm afraid you likely need the KB.
    (basically a bodged voltage board worked out cheaper to get u.k. sales)
    Yours may look the same to others but they'll likely have the 180v motor too.
    Like this:
    https://www.ebay.com/itm/393622606533
    I may have updated previous post too while you responded.
    Ergo 180/90.
    Like this:
    Ah, this might explain why I can only get 100V out of it. Hmm. There do seem to be fairly cheap PWM DC-DC controllers on Ebay which I could maybe bolt on
    Did you have it running before?.
    Did you plug it in and pretty much blow the lot by any chance?.
    Everything I look into so far is showing me schematics with 110v input.
    This suggests to me that there should be a 220v-110v transformer in there for use with u.k. supply.
    Okay so. From what I said previously.
    On this Denford data page in the 4th post down:
    https://www.denfordata.com/bb/viewtopic.php?f=36&t=2929
    The schematic shows the 'power transformer' which converts u.k. 240vac into 110vac for the machine.
    Micromill-electrical-feb-2000.pdf
    https://www.denfordata.com/bb/download/file.php?id=2796
    Micromill-denstep-electrical-June2000.pdf
    https://www.denfordata.com/bb/download/file.php?id=2795
    Look for this in your machine. Could be the overall culprit.
  1. Boxford 160 TCL -Lenze 534 DC motor Driver Board
    By JohnnyK in forum General Electronics
    Last Post: 01-09-2021, 10:22 AM
  2. Sprint 400i DC motor controller wiring
    By Ross77 in forum Spindles & Drive Motors
    Last Post: 16-09-2017, 09:19 PM
  3. Driver and board recommendations
    By sternfox in forum Motor Drivers & Controllers
    Last Post: 25-09-2016, 08:16 PM
  4. WANTED: Routout CNC Driver Board 2.5 amp Single
    By fozziebear40 in forum Items Wanted
    Last Post: 29-03-2012, 07:36 PM
  5. New SCR driver board, or new motor & VFD?
    By m_c in forum Motor Drivers & Controllers
    Last Post: 04-11-2010, 05:16 PM
