    Lives in East Lothian, United Kingdom. Current Activity: Viewing Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    I've not really been following this thread, but the simplest option is a 4PDT relay as has been suggested, but you only need to switch the Dir+/-, and Step +/- signals.
    Driver is permanently enabled, so you don't have to worry about it losing power and the Z dropping.
    And the GND is only needed for the main power, as the driver inputs are optoisolated.
    The only issue with using a relay is with switching such a small current, the contacts will likely oxidise with use due to lack of current to wet/clean the contacts, eventually leading to lack of continuity,
    For a circuit only switching occasionally, it'll likely be a long time before failure is likely to be an issue, but it's something to bear in mind.
  2. The Following User Says Thank You to m_c For This Useful Post:
  1. How to wire the enable pin on a stepper drive?
    By cncJim in forum General Electronics
    Last Post: 01-01-2016, 05:10 PM
  2. WANTED: parker CD20 stepper drive
    By drumsticksplinter in forum Items Wanted
    Last Post: 29-03-2014, 03:35 PM
  3. Wanted: Parker CD20 Stepper Drive
    By drumsticksplinter in forum Classified Ads, Buy, Sell & Swap
    Last Post: 29-03-2014, 03:33 PM
  4. What voltage for stepper drive?
    Last Post: 22-01-2014, 10:49 PM
  5. BOB & Stepper Drive
    By GTJim in forum General Electronics
    Last Post: 22-08-2013, 07:17 PM
