Thread: Run a stepper from 2 DM542 drive
10-12-2021 #1
Hi all,
I need to control safely a stepper with 2 drives (cheapo DM542). I have a fiber laser which has a Z axis controlled by a board DLC2 (step and dir) thru a DM542 to a stepper. I have another device which has his own driver (also a DM542), but needs to acces the same stepper.
The process should be like this:
- start the machine with the Z axis stepper using the DLC board;
- push a button to use the other device - isolate the DLC board and the drive and let the other drive to take control;
- push another button or use the same one to be back to the normal state (at start up).
I am thinking to have a relay of some sort or a contactor which needs to be to a board for the step and dir, but this is vaguely.
What is your advice on this?
Gabi
11-12-2021 #2
Another option would be to use only one driver and switch the control signals (step, direction, and what else you have) between the two devices.
Jan
11-12-2021 #3
11-12-2021 #4
Well, if the DM542 drivers are already built into two different machines, my suggestion might be more work.
What you need to do it the way you described would be a 4p2t (4 poles, 2 throw) switch or relay.
This can switch the 4 wires of the stepper between 2 sources, but the switch has to be rated for the full current of the steppers.
Jan
11-12-2021 #5
11-12-2021 #6
This is what I am afraid. Blowing a driver is not that bad (they are cheap), but the board of the laser is £1000. Open to any working solution. Thank you
11-12-2021 #7
11-12-2021 #8
12-12-2021 #9
Skip one driver and switch the control signals step, dir, enable and gnd. This is what I am doing on my DIY lathe / 4th axis combo. I would not switch the stepper wires. Beware that if you have some interference then you might get some extra steps, so you must be careful with the wiring.
12-12-2021 #10
The only safe way is to switch the step/dir signals, you will 99% blow the drive if you swap the motor wires when the drive is powered up.
Email: [email protected]
Web site: www.jazzcnc.co.uk
There are currently 12 users browsing this thread. (0 members and 12 guests)
How to wire the enable pin on a stepper drive?
By cncJim in forum General ElectronicsReplies: 8Last Post: 01-01-2016, 05:10 PM -
WANTED: parker CD20 stepper drive
By drumsticksplinter in forum Items WantedReplies: 0Last Post: 29-03-2014, 03:35 PM -
Wanted: Parker CD20 Stepper Drive
By drumsticksplinter in forum Classified Ads, Buy, Sell & SwapReplies: 0Last Post: 29-03-2014, 03:33 PM -
What voltage for stepper drive?
By Davek0974 in forum Plasma Table MachinesReplies: 1Last Post: 22-01-2014, 10:49 PM -
BOB & Stepper Drive
By GTJim in forum General ElectronicsReplies: 9Last Post: 22-08-2013, 07:17 PM
