Hi Cynic
The link below points to a build I worked on with a mate a while back 2013. The machine is still being used almost daily by the men's shed where it is set up. the X and Y axis uses timing belts. the only changes made have been two Makita routers, and now it is on its second 2..2KW Asian spindle. Yes it is used a lot.
If the timing pulleys and belts fitted to your robot bits are in good condition I would give them a try.
It is worth remembering that the total accuracy of a machine is the sum of all the parts and how they are aligned. Timing belts do work as this machine has proved.
Regards
John
Regards
John
https://www.machsupport.com/forum/in...?topic=23730.0
