Thread: popendent 1 versus pokeys55T
17-12-2009 #5
Andre,
I moved this thread to a better place...
In answer to your question, you can connect all wires directly from the IMS pendant to the PoKeys55 as any pin can be configured for any purpose, including the rotary encoder A/B lines (as long as your Pokeys55 is version 1.7 or later). However I would avoid Pokeys pins 43 - 47 as these can be configured for analogue input/output as well and it would be silly to tie these up for the pendant.
The only area I cant be sure about is the pendant indicator light (IMS wires 5 and 6) as this is intended to work on 24v, and the Pokeys55 only outputs 3.3volt. If you want to drive the indicator light you will need some additional components.
Gary at Zapp may be able to advise better on this as he sells the IMS pendant.
Links to data sheets:
PoKeys55 User Manual
IMS pendant (on Zapp site)
