26-03-2010 #31
I think auto-toolchangers have a locking plunger with a solenoid or stepper driven retractor to lock the post and a switch to indicate the plunger is clear so that the software wont turn the post until it unlocked. A switch to show the locked position would also be useful.
08-05-2010 #32
hi guys
i tried running the hex code on proteus and the processor is been reset every 23secs by watchdog timer. itried compilling the v1.1 still the same problem. can someone tell me what i am missing
08-05-2010 #33
24-08-2010 #34
thank you for your contribution I'll start gattering the parts and beguin on the project, I do have one question do, how it will afect the table if i use gear reduction or do i have to use it with a straight shaft and no reduction?
24-08-2010 #35
It depends on what you mean by reduction gear.
If you simply mean the worm on the table (i.e. in the case of a 6" vertex which is 90:1 reduction) then it's designed for that.
If you wish to reduce the gearing further by driving the input shaft to the table via a reduction gear then you can do it providing you're not reducing it by too much.
Basically it's down to the maximum number of steps for a single 360 degree rotation of the table. These can't exceed 65535 steps. So with a half stepping (400 step) motor, and a 90:1 reduction ratio the number of steps per 360 = 400 * 90 = 36,000.
If you tried to drive this through a 2:1 reducer you'd need a value of 72,000 which is too high.
Hope this helps
Steve.
24-08-2010 #36
Thank's Steve, i did mean the worm on the table, i was'nt sure if the controller was designed for that, so it should'nt be any trouble, i apreciate your time.
17-11-2010 #37
Hello,
Many thanks to everybody for these informations.
I'd like to built an indexing device for my watchmaker lathe.
My knoledge in electronics is not perfect, so is someone able to provide me a printed board ?
Regards, Petrus (France )
19-11-2010 #38
Hi Nipper;
there is someone in OZ that has done a tool changer for a herbert lathe, I think that is
in SA , he is a nice fellow , have a look at this
http://www.cncathome.com/latheturret.html
also there is a very nice fellow in Melbourne ,his name is Frank Tkalcevic, he is
very active in the emc forums .
regards from Sydney
mariano
mariano
29-11-2010 #39
Attached to this post V2.12b firmware.
A couple of minor bug fixes, couple of minor new features and a change to the way the worm ratio is entered, rather than enter a worm ratio (and the device 'assume' a 400 step motor) you now enter the worm ratio multiplied by the step ratio.
E.g for a 400 step motor and a 90:1 worm you'd enter 400 * 90 = 36000.
This change allows odd ratios to be entered.
I'll upload updated instructions shortly.Last edited by Kwackers; 29-11-2010 at 06:18 PM.
09-12-2011 #40
Diy 4th axis rotary table using 100mm chuck with minimal backlash
By kingcreaky in forum Linear & Rotary MotionReplies: 3Last Post: 05-09-2013, 01:03 PM -
Which chuck to fit 6" rotary table??
By wiatroda in forum General DiscussionReplies: 19Last Post: 10-08-2011, 08:47 AM -
Mounting a chuck on a Rotary table
By irving2008 in forum Machine DiscussionReplies: 17Last Post: 02-09-2010, 07:23 PM -
Rotary Table CNCing
By irving2008 in forum Gantry/Router Machines & BuildingReplies: 21Last Post: 19-02-2010, 11:57 PM -
Setting up work on the rotary table
By irving2008 in forum Machine DiscussionReplies: 6Last Post: 09-01-2010, 10:27 AM
